跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
It's not working and recovery adb problem
Hi *
I unlocked my Nexus 5 n root it n install twrp recovery n install cyanogen mod 13 with gapps
Then I opened super su it says update the software I click on update cwm/twrp
After that it shows only google screen I have done hard factory reset.
Nothing is working.
When ever I turn on my phone only text google appeared with an unlock image
I can't apply adb update cm recovery
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you are fine with losing the data, you can reflash the os (https://www.google.com/url?sa=t&source=w...) over the bootloader interface. That would remove CyanogenMod and wipe your data, but your phone should run properly on stock Android again. since your bootloader is unlocked, you could also flash just a new custom recovery, for example twrp, and use it to flash a zip containing CyanogenMod, if you have one have one on your phone. The procedure is basically the same, but instead of downloading the system image, you download the custom recovery and run the command "fastboot flash recovery <file path for custom recovery>" to just flash the recovery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Osman Shaik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 184
