跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Why do I have to jiggle power cord will not stay green
Why do I have to jiggle power cord will go green for a second but then goes to orange. It will not stay on. Could there be a short in the cord or connection?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The color changing simply means it's charging your battery. The outer ring of the AC plug jack can get spread aprt thus preventing secure connection. It can be squeezed back till it's tight. You may also have a damaged DC-IN port. That can be replaced but only after you are sure the jack is tight.
Here's the part you may need: [关联产品丢失或禁用: IF155-065]
Go here to exactly identify your correct PowerBook before ordering any parts: http://www.ifixit.com/Mac-Parts
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,079
