跳转到主内容
Micromax Canvas 2 Plus A110Q is a dual-sim Android smartphone by Micromax Mobile launched in May 2013.
13 个问题 查看全部
sd card not supprted
1 sd card not support
2 network problems
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
What are your network problems?
完成的
添加一条评论
1个答案
Go to settings on your phone. Tap on storage . Tap on portable storage. This should tell you if your sd card is mounted. If it is not, tap on portable storage again. This should mount it. If you have pulled the sd card out without unmounting it, it may be damaged. I hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
satish kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 181
