跳转到主内容
Personal hand-held video camera released by Aiptek in 2006.
4 个问题 查看全部
,how to delete pictures?
How do I delete pictures,etc?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You probably have figured it out by now, but per owner manual:
1.) Power ON - flip out screen and find power button on body of camera - the button will light up blue when ON
2.) Press MODE button - immediately underneath direction button circle on back of camera and to the left labeled "MODE"
3.) Use the DIRECTIONAL CIRCLE joystick button above the Mode Button to select PLAYBACK mode
4.) Press down on DIRECTIONAL CIRCLE joystick button for OK to enter the mode - OR - press the PLAY/PAUSE BUTTON (|>) on left bottom side of screen frame
5.) The screen will display any thumbnail index of pictures stored in camera memory. (If no pictures are showing then there are no pictures in camera's memory. ) In this mode press down on DIRECTIONAL CIRCLE joystick button for OK to enter the FULL-SCREEN mode. While in the full-screen mode press MENU button to switch back to index mode. Or, if the zoom ratio is set at 1.0x you can move the directional button DOWN to switch back to thumbnail index mode.
  • a.) In the index mode: use directional buttons to move to selected picture to highlight the box around it.
  • b.) In the full-screen mode: use the directional buttons to move to the previous of next picture.
6.) Select picture
7.) Press MENU button and select which option you choose:
  • -DELETE ONE Picture that is highlighted - then select YES/NO.
  • -DELETE ALL Pictures in camera's memory - then select YES/NO.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cindy Glines 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 154
