Why is my backlight not working?
I have replaced my digitiser on my iPad mini, and the LCD backlight has stopped working. I have tested the backlight Fuse and Diode with my multimeter and they both seem to have continuity.
Go into settings and make sure the backlight isn't turned all the way down. It defaults to the during repair sometimes. If its not, then its almost certainly a backlight filter. There is more than one to check.
Google for the schematics, then inspect the appropriate ones. You can usually spot the blown one with a microscope and its a bit safer than poking around with a meter.
这个答案有帮助吗?
Thanks... I checked the brightness in settings and its turned all the way up so it's not that. I have checked the backlight filter and backlight diode and that seems to have continuity. Are there anymore that these two? I couldn't see any others mentioned online? And couldn't find any schematics online..
Often times, a reset will solve the problem. I have changed dozens of digitizers and lcd's in iPads and have simply gotten into the habit of doing a soft reset every time. Try that and I am almost positive it will solve the issue.
这个答案有帮助吗?
Thanks.. I have done a reset by holding down the Power & Home button and that hasn't solved it either..
George, it might be a damaged lcd or it might be a problem with the motherboard. I would try a different lcd if you have one...
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 341
i would try the soft reset ... sometimes it works ... other than that you might have to open it up again and, disconnect the battery and reconnect... this happens a lot when changing the digitiser.
由 Reboot Gozo 完成的
Thanks I have tried a soft reset and disconnection of battery and still the same!
由 George 完成的
