跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3285 个问题 查看全部
iPhone 4 front frame replacement
I dropped my iPhone 4 accidentally and there is now a small chip at the bottom of the front panel, its a piece of rubber that came off.( The black rubber that surrounds the front glass) Although its pretty small, i'm kinda bothered by it but I have found a replacement for it. I would just like to know if its easy to replace that part? Is it easily removable from the front glass panel?
http://www.chinaontrade.com/apple-iphone...
Thats where i found the part.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
已选择的解决方案
Um, wow. Just to remove the display assembly, you have to pretty much disassemble the whole phone.
iPhone 4 front panel assembly
You will then have to figure out how to get that piece off of the display assembly, which may be really difficult, seeing as the glass and display are securely glued together (check out step 22 and the associated description). The part is also most likely glued to the glass, and hopefully not sandwiched by the display. If that is the case, carefully use a heat gun to loosen the adhesive and gently pry it away from the glass. For the new part, apply a new adhesive, let set, and put it back together.
Unfortunately, I don't have one to do this to myself, but if you are feeling up to it, and it works, please photo document the process and post a repair guide for others to follow.
In short, is it easy to replace; probably not. However, is it worth it; quite possibly yes.
这个答案有帮助吗?
得分 0
添加一条评论
iPhone 4s front glass replacement
这个答案有帮助吗?
得分 0
添加一条评论
You will have to take the whole iPhone apart. you can see a video how to do it here http://youtu.be/JapCRFqLmEY
After just put the plastic frame away from the glass and LCD assembly.
Plastic part is glued to the glass by a thin strip of adhesive so it is not hard to take apart.
If you are looking at the front of the glass pull the frame away in left and right direction not downward, because the plastic frame comes in btw the glass and lcd and you can damage the lcd by pulling the frame downwards toward LCD. Remember you can always use heat gun or blowdryer to make it easier.
Hope that makes sense : )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wai Soong 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 5,815
