跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
i can hear the caller but they cannot hear me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
最有帮助的答案
your microphone may be bad or disconnected, i believe that ifixit has a guide for this.
这个答案有帮助吗?
得分 1
添加一条评论
If the microphone is indeed bad, you'll probably be better off buying a whole new dock assembly. Unless you possess mad soldering skillz, you'll find it hard to get everything to go back the way it should.
这个答案有帮助吗?
得分 1
1条评论:
How do I find out if mic is bad?
完成的
添加一条评论
Seriously, sometimes it's just AT&T's network having issues, especially if you hangup and try again, and it works just fine. This happens to me quite a lot.
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried restarting and restoring the phone?
这个答案有帮助吗?
得分 0
1条评论:
Yes, but still encounter the problem. Please help. I never dropped it that is why i wonder what happened, the phone is just a year in use.
完成的
添加一条评论
Want to fix the problem, from the above discussion it appears to be the phone mic is not functioning. Is it worth fixing or replacing the mic?
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I’ve just had my charging port renewed on my iph8. When I got it back I noticed when making calls I can hear the person I’m calling but they can’t hear me. I created a voice recording through WhatsApp and it’s just static noise. I plugged my headphones in and made a call again and the other person seems to hear me fine through heads phones, this fault was not apparent before the charging port renewal. Please can you advise ? TIA
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Teddy Poynor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,501
