跳转到主内容
A line of child-friendly tablets by Fuhu.
107 个问题 查看全部
Power chord doesn't fit (may have been bent) and doesn't charge.
Can no longer fit the power chord into the charging portal. The chord has a purple mark on it like it over heated. The dreamtab doesn't charge anymore. Could the charging port be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Most likely you need a new charger if the cord is damaged. Also inspect the socket on your tablet to see if one of the pins is bent or damaged before trying the new charger, hopefully its just the charger.
Here's a link to a new unit: nabi 2: Charger Replacement
这个答案有帮助吗?
得分 1
添加一条评论
The charging port can be replaced but requires a new board snd the ability to solder. You can find a new board on ebay for under $300.
这个答案有帮助吗?
得分 -2
1条评论:
Sherry - Sometimes the simple answer is the answer.
完成的
添加一条评论
添加你的答案
dreemquilter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 60
