What I do after land in water
My dji landed in water then its not started so what i do
Hi,
Rice is good to eat but does nothing to fix the problems caused by a mix of liquids and electronics.
First remove the power from the device, then follow this guide about how to clean the device and hopefully get it working again.
这个答案有帮助吗?
Hi, I have a bebop that took a swim. I placed it in rice which helps absorbs water and placed the container in the direct sun over two days and at night I put it in a box with a light on. Took it out and fired it up. It works , the only down side is the camera is a bit blurred.
这个答案有帮助吗?
Hi guys. I dropped my dron in the water. I will try it to do that think with rice if will not working any one of you guys know some one who can help?
There is my email address: bkosinski21@gmail.com
Thanks
Bart
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 405
1条评论
I can only suggest what to do. Try putting the DJI drone and batttery into rice. It should remove moisture and give you a better chance of recovering the drone.
由 Imad Knight 完成的
