跳转到主内容
Why my laptop doesn't turn on even though I press power button?
Hello to all,
I have a Toshiba A200D.
I have changed :
1. Hard Disk
2. RAM
3. Charger
4. Screen
5. CPU
I connect it to the power cable, you press the power button, and the light of "charging" coming on ,and all the other lights and then IMMEDIATELY they come off,without even the fan spinning.
Most probably the motherboard is dead,but what could be the "defect" part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
No thoughts anyone ?
这个答案有帮助吗?
得分 0
添加一条评论
i have gone through same problem once mine was SMPS adapter issue
i am quite sure its your is also SMPS adapter which may be not working...you can get it repaired or changed
这个答案有帮助吗?
得分 0
添加一条评论
Did you see that i have changed the adapter / charger ?
Or you didn't even pay attention to it ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 53
