跳转到主内容
戴尔所制造的笔记本电脑。
3027 个问题 查看全部
What is this loud popping noise
why does my dell laptop make a sudden loud popping noise, similar to what a small fire cracker would sound like? Sound is very startling and I am wondering if it is a fire hazard ? This is not a consistent problem. It happens randomly a few times over the course of several months.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The "loud popping noise" you are hearing may simply be the sound of a foreign object caught in the one of your laptop's fan(s). I'm thinking of something like a small piece of plastic, wood sliver, or perhaps even a small crumb of "crunchy" food (potato chip, grain of rice, etc.) here. Something small enough to get sucked-up by the laptop's fan and lodged somewhere within.
I list a few possible yet somewhat specific things that could be caught in your laptop's fan because I had similar issues with a number of my past laptops. In my case, it was a small piece of plastic from the corner of some thermoformed packaging. This stuff is sometimes called a blister pack or clamshell, and it's that crazy-annoying, anti-theft clear-plastic packaging (sometimes with a stiff piece of cardboard sandwiched within) that most off the shelf, small, electronic products are packaged in these days? You know the stuff.
Anyhow... when I noticed a similar noise coming from my laptop, I could lift it up in the air and gently shake the laptop, and most times, the noise would go away. ...and then it would come back at seemingly random times.
One day, I took the back case of my laptop off, found that little sliver of tough clear plastic, removed it, and put the case back on ... problem solved! I figured this piece of plastic must have come from a recently opened blister pack that was missed and left on the counter or something.
I've also had a similar experience with a noisy laptop fan on a friend's laptop. We found chip crumbs caught on some lint around his laptop's fan. Once vacuumed-out, all better.
Good luck!
_rs
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jjoh424041 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 4,777
