跳转到主内容
Why doesn't my 24-70mm focus at 24mm?
I found that my lens does something odd at 24mm. Its a canon 24-70mm 2.8L that won't autofoucs at 24mm. If I turn it slightly to the right, it works fine. But all the way out at 24mm, it just struggles to focus and will not lock onto anything. The only exception is when the target is something very close to the camera (like within 2-3 feet) in which case it will focus. But anything else that is further away won't work.
Thank you,
Sarah
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Were you ever able to find a solution for this? I have exactly the same problem. Is your zoom ring sticking around 70mm?
完成的
添加一条评论
1个答案
Hi, chances are the flexible aperture ribbon has cracked and causing these issues, all Canon zoom lenses at some stage will have this part wear/break and require replacing, average lifespan of part EF-S lenses 2-5 years, EF lenses 5 years, EF L Series 5-10 years.
See your local repairer the repair cost is economical on this lens.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah Ros 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 615
