跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why won't it turn on
My phone keeps turning off even when the charge hasn't finished so I can't use it and it won't come on so my question is that why does it do that and what can I do to prevent it happening cause it only works every three days when I put it in charge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I would be grateful I had an answer to this I need it to stop
完成的
添加一条评论
2个答案
已选择的解决方案
I agree with the first answer. If your battery is older than 2 years it might be time for a change.
这个答案有帮助吗?
得分 1
1条评论:
Thank u that is really helpful thanks @natilious
完成的
添加一条评论
最有帮助的答案
Try a hard reset. Press and hold the power and home button until the apple logo appears. If that doesn't work, replace the battery.
这个答案有帮助吗?
得分 4
1条评论:
Thank u I'll try that out as soon as ossicle thanks again
完成的
添加一条评论
添加你的答案
LOLA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
