Can I remove the sensor cable to disable the front camera?
In this step, the front-facing camera and sensor cable are disconnected.
I would like to know if the front camera is able to function without this cable being connected. I would like to disable my front camera.
4条评论
Apparently the phone will be stuck at the apple logo if the sensor cable is not connected. Is this supposed to be the case ?
由 Daylen 完成的
I think it will be best if u didn't do that and an expert did cause like u
can get electrified and that could lead u to certain death cause I have seen this happen
由 LOLA 完成的
Ummm..... The battery is only about 4 volts.... You can't get killed by this unless you stab the battery repeatedly with a knife and it blows up...
由 Gigabit87898 完成的
LOLA has seen people be electrocuted by a phone? I've shocked myself more times than I can count. Heck...you can't even feel the low voltage on a phone.
OP: I wouldn't disconnect the whole cable. Besides the errors it could throw, your screen would be on all the time on calls. Its annoying.
由 Josh W 完成的
