跳转到主内容
Boots up but black screen
My 17" 2007 MacBook had the screen go black while I was working.
I rebooted holding down control alt shift I believe that was it and it came back on.
Now it's done it again. Power button turns it on front light comes on and slight screen glow near bottom.
Gives a single long shrill tone then the standard chime when power button is depressed. I can feel hard drive spinning seems to stop at usual amount of reboot time. But screen still dark.
Any help is greatly appreciated
Thanks! Ron
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Just to be clear here you have a PowerBook or a MacBook Pro? These are very different systems. Your model info in your question and what you selected are not the same.
完成的
添加一条评论
2个答案
已选择的解决方案
A single tone indicates there is no RAM installed:
https://support.apple.com/en-us/HT202768
这个答案有帮助吗?
得分 3
2条评论:
Yes exactly. this means that one or both of your ram modules are busted.
Sorry bro :(
完成的
But it also could be the wrong RAM. Without being sure what the system is the Beep code is not enough to isolate if the slot is the problem. Most likely, it is.
完成的
添加一条评论
Looks like a problem with your RAM (I had similar one).
Try removing the RAM modules one by one from their slots and booting it again
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 777
