跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Replacement 42mm Screen doesn't fit
I purchased a replacement screen from iFixit and followed the replacement steps. Now when I am putting everything back together the screen doesn't want to fit back on. It sits flush all of the way around except fro the top. When I look at the side that is not closing properly I see two little tabs that don't appear to be on my old screen. Now I am not sure if they were at some point part of the original screen since the screen was broken and came off of the watch in pieces. Here is a picture that will hopefully help show what I am talking about.
Thanks
Chris
Update (08/23/2016)
Here is another picture. It shows the side where the clips should clip into.
Update (08/23/2016)
After resetting the watch and repairing it, it appears to work properly but I still can't get the screen to sit flush.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Can you see any broken clips under where these tabs go?
完成的
its like there are no spots for the tabs to slide into
完成的
I'll take another picture when I get home in a couple of hours
完成的
添加一条评论
2个答案
已选择的解决方案
As far as I know, and by looking at several pictures from ifixits guide, parts and google images, the Apple Watch LCD shouldn't have clips, as the screen is held down by double sided adhesive.
I would contact them about it to see what can be done, as their customer service is fantastic. :-)
这个答案有帮助吗?
得分 1
添加一条评论
We’re going way back here but I'm running into the same issue with parts from a different supplier. These look like apple original take offs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 277
