Replacement 42mm Screen doesn't fit
I purchased a replacement screen from iFixit and followed the replacement steps. Now when I am putting everything back together the screen doesn't want to fit back on. It sits flush all of the way around except fro the top. When I look at the side that is not closing properly I see two little tabs that don't appear to be on my old screen. Now I am not sure if they were at some point part of the original screen since the screen was broken and came off of the watch in pieces. Here is a picture that will hopefully help show what I am talking about.
Thanks
Chris
Update (08/23/2016)
Here is another picture. It shows the side where the clips should clip into.
Update (08/23/2016)
After resetting the watch and repairing it, it appears to work properly but I still can't get the screen to sit flush.
3条评论
Can you see any broken clips under where these tabs go?
由 Harley Greaves 完成的
its like there are no spots for the tabs to slide into
由 Chris Martin 完成的
I'll take another picture when I get home in a couple of hours
由 Chris Martin 完成的
