跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20001 个问题 查看全部
Won't turn on at all
Came home my MacBook Pro was powered off, plugged in the MagSafe charger, I let sit overnight plugged in.
In the morning I turned the system on but wouldn't let accept my password, turned off won't power back up now, tried SMC reset,
The MagSafe charger didn't change from Amber Green
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It was asleep I'm guessing I wasn't home, I came back and it was off, after the password issue I clicked the power down icon on the login screen. It does nothing at all and I tried that I get no change in the light on the charger
完成的
添加一条评论
1个答案
最有帮助的答案
Please provide more detail according to following points:
  1. Macbook was off? sleep or shutdown? also what state had you left it in last time you used it?
  2. After it didn't accept your password, did you force shut down or shut down normal way?
  3. "won't power back up" what happens when you press the power button? the screen just stays blank, or you get some sort of display?
You could also try resetting your NVRAM by pressing (cmd-option-P-R) at the same time and pushing the power button. don't let go of these keys until you hear startup chime TWO times.
Lastly, try booting from a USB drive or DVD disk with Mac OS installed on it.
Update (08/23/2016)
@ssdw if that's the case I would try to reset NVRAM and also SMC. The instructions for that are given on these sites
https://support.apple.com/en-us/HT201295
and
https://support.apple.com/en-us/HT204063
if that dosent work, then I'm afraid its a hardware problem likely to do with your logic board or display.
这个答案有帮助吗?
得分 1
3条评论:
If the logic board is bad where do I find one and will I loose what's on the hard drive?
完成的
@ssdw no you will not loose your hard disk data.
However I just realized that the problem could be keyboard(the password was wrong and the power button is in the keyboard).
so when you try to turn It on try to listen for hard disk whirring noise or fan noise when you start it up.
完成的
Tried the nvrm and I still get no chime no noise no nothing
完成的
添加一条评论
添加你的答案
Spencer Pfenninger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 180
