跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
3DS doesn't charge (new charging port already installed)
Hello and thanks in advance! I have an otherwise fully functional 3DS XL, however it doesn't charge. We already desoldered the old charging port despite it looking completely undamaged and intalled a new one. I'm not really experienced with soldering but it holds and all contacts are properly connected with the motherboard. We tested the circuit with a digital multimeter and all seems to be fine. We tested continuity between the charging port and the battery connector and it shows the same values as a 3DS XL with functional charging port. What could be the reason for this behaviour? Is some part of the motherboard damaged?
Best regards,
Johannes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I believe it is the fuses on the board you should check the continuity levels of them I'm having the same issue looking for more info on it bit that's the best I have come up with so far
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Delete Me 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 244
