Why does the screen go black when gas range spark igniters fire?
My tv screen goes black when the spark igniters for my gas stove are activated. This is a new problem. The stove and the tv have been installed for several years with no problem before.
11条评论
Hi,
Seems as though the EMR ( ElectroMagneticRadiation) produced by the ignitors may be interfering with the TV signal.
Has anything been changed at all, for instance the location of the TV, which power outlet it is plugged into, the TV aerial location? What is the model number of your TV and also your gas stove?
由 jayeff 完成的
Does the screen remain black or does in come back within a short time? Do you have to turn the tv off and back on again to get the picture back?
由 Alan Liefting 完成的
The screen is black only for the few seconds that the igniters are firing, then it recovers immediately. It's an LG flat screen. I haven't changed anything as far as location, etc. etc. The TV is plugged into an outlet that is on the same circuit as the stove, but that has always been the case. I have checked the grounding on the circuit and it checks out ok. The gas stove is a Kenmore.
由 Geoff Pope 完成的
Whoa u should be very careful like who knows what's gonna happen
由 LOLA 完成的
Idk about that I mean it would be best not to ask me cause idk about that I mean that's bad it should go to junk
由 LOLA 完成的
显示更多的6条评论
