跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Why does my iPad have colored lines across the screen?
As you can clearly see from the image, there are several multicolored lines across the screen. The device was shipped from my mom in the states last week, it was in perfect condition before she sent it.
Any workarounds? Maybe fixes I can do manually?
TYVM!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Start with a factory reset. Its unlikely that will fix it, but its the easiest fix. If that doesn't fix it, open it up and check the LCD connection on the motherboard. Make sure its seated will and there is no debris in there. Test the screen before you reglue the digitizer.
I'm posting this as a comment because I ran into a few Airs that gave me this same problem and I never did figure them out. Hopefully its something simple that a reboot or reseating the connector will fix.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same thing on my old PSP this is dead pixels the screen display was probably damaged in shipping the only way I know how to fix this is to go and get the display changed if you don't have a warranty this can be vary experience so if you don't you might have to just deal with the lines
这个答案有帮助吗?
得分 0
添加一条评论
I did have same problem. Did a hard reset, by pressing Home and sleep/button. Solved.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ice3303 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 18
总计 3,031
