跳转到主内容
The third iteration of Lenovo's Yoga line of notebooks, similar in design and hardware to its predecessors. Designated by model number 80HE000DUS.
20 个问题 查看全部
Plastic strip on bottom of display
I have replaced the display (not for the faint of heart) and everything is working beautifully. However, I can not get the plastic strip to stick back on to cover the screws at the bottom. Do I need to buy a heat gun to melt the glue? I want it to look perfect.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
i used plastic super glue to fix mine about 2 months ago and its holding up beautifully. just used four small drops along the strip and held each one for about 45 seconds.
这个答案有帮助吗?
得分 0
添加一条评论
Try some double sided tape and blow dryer. Apply the tape to the rear of the plastic, and heat carefully with the blow dryer to form a tacky surface more than what the tape is now. This will also insure a tight bond of the tape to the plastic. CAUTION! DO NOT HEAT MORE THAN NECESSARY!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
karengail 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 197
