跳转到主内容
Repair guides and troubleshooting for the Bodum Bistro Electric Blender Stick. These immersion blenders can reach speeds up to 20,000 rpm.
3 个问题 查看全部
Motor working but blade not rotating
Motor is working as sound is coming but the blade ia not rotating and hence blender isn't working..
Is there any shop in botanique, brussels where I can get it fixed?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Hi, if you still have your Bodum Bistro Electric Blender Stick but youre no longer using it, I would be interested in buying the small blade from you, as I have lost my own, and Bodum no longer provides parts (nor does any other store I contacted).
完成的
添加一条评论
1个答案
Hi, you don’t need any fixing store to fix it. Probably the issue with the metal pin, which brings rotation power from the motor to the blades. Check how I repaired my blender, easily on repair your blender, easy fix video.
And it will costs you few cents, in the repair shop they will charge you at least 10$ for the fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Foram Shah 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 35
总计 1,588
