跳转到主内容
修复你的物品
维修的权力
配件 & 工具
What kind of resister should be used in my laptop?
My laptop fan standard 5v 0.35a, the original sound really loud. It became very light when I plus a 30 ohm resistor--http://www.kynix.com/Parts/868678/HR0130.... But the temperature will getting higher when cpu was busy. Should I change it ? What kind of resistor should be appropriate? Or is there some formula or not? I will be very appreciate if you give me some advice. Thanks a lot!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
@amandali this is not a resistor issue but a fan issue. As you have noticed by adding a resistor you are impeeding the fan and running a chance of over heating. Replace your fan.
这个答案有帮助吗?
得分 3
评论:
Thanks a lot. I have already replaced my fan.
完成的
添加一条评论
添加你的答案
AmandaLi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 47
