跳转到主内容
Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
11 个问题 查看全部
Tablet doesn't turn on
Acer iconia tablet a3-a10 doesn't turn on just a light flicker tried soft and hard reboots and no response
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论:
How many amps does it draw from the usb charger? Check with a multimeter by splitting either +power or -power and put the probes on the resulting 2 ends of wire.
完成的
Ethan can you tell me about the solution to that problem? i have the same problem, and I need resolve it soon, Thank you
完成的
Yea, as @David said check all the connections and reseat them. Does it get recognized by a PC?
完成的
Hi guys same problem any way to fix it
完成的
hi cliff
my tablet appears to be fully charged , but will not start up
I had to press hard, then harder still, It would now appear that the power switch has failed, is it difficult to replace it
Scott C
完成的
添加一条评论
2个答案
might be a LCD cable not plugged in all the way.
这个答案有帮助吗?
得分 0
添加一条评论
'''it's too easy Guys .
-If you are unable to start the process for your tablet does not answer the Preloader mode, you need to remove the back cover and disconnect the battery and start the tutorial battery disconnected.
Once the tutorial finished, reconnect the battery. put in charge 10 min and then attempt to restart.
1- remove the back cover.
2- disconnect the battery.
3- reconnect the battery.
4- put in charge 10 min.
5- attempt to restart.
GOOD LUCK
[RYAN KHENNOUCI]
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cliff Booth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,615
