iPhone 5s LED Flash and buttons not working
my iPhone 5s 's LED Flash and buttons not working except home button that works fine
the problem happens after my phone's fall
is it a hardware or software problem and how to resolve it
Well if you're a tech and know how to open up your phone you can do that
As you mentioned that only home button is working you probably can't do hard reset(home + lock button)
You can try to disconnect the battery and re-attach it after a few sec to see maybe this will bring back your buttons
Otherwise you might try to change flex cable where all the buttons and a flash are located
There should be a guide on this website if you never had done it, but if you're not a tech i would leave it for someone else as it's not the easiest task!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
