iPhone 5s buttons not responding exepte home button that works fine
my iphone 5s buttons not responding except home button that works fine
and the volume and mute and power buttons not working at all
and the problem happens when my phone is fall
Check the connector that controls it, it is this one:
这个答案有帮助吗?
thanks i will try thaat i noticed that also led flash not working you think that it's the same connector
Yes, I'm pretty sure led flash is same connector.
he mute switch, volume buttons, vibrator and the power button is connected to one flex cable. And the flex cable is connected to the motherboard under the LCD connector. Check if the connector is loosen or not
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 72
