跳转到主内容
MacBook, MacBook Pro, 和 MacBook Air 交流电 电源适配器。
65 个问题 查看全部
85 W adapter only registers as 60 W adapter, help?
I did this cable repair recently on an apple 85W adapter (not counterfeit, the one that came with the laptop purchased directly from apple) and the system now reports that the connected charger is 60W instead of 85W. Any idea why this would happen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have same issue with my 85W Magsafe. I purchase the new magsafe cable from eBay, and detected as 60W.
完成的
How do you know it was detected as 60W?
完成的
添加一条评论
2个答案
已选择的解决方案
Download and run Coconut Battery and see what it tells you about the Mag-Safe.
http://www.coconut-flavour.com/coconutba...
这个答案有帮助吗?
得分 3
添加一条评论
You should buy a 85W cable, it will work.
It looks like the 60W cable but different component inside the plug.
There is three types of cables: 45W, 60W and 85W.
A 45W cable soldered to a 85W charger will charge with only 45W.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
steve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 490
