跳转到主内容
Release Date October 2015 Model Number M4C63UA.
Why won't my laptop turn on after disassembling and reassembling it
I did a system restore in settings because my internet kept crashing and when it finished it never went passed the HP loading screen and then it would go black. It was like this for a few days and I tried everything to fix it Bios scan command prompt, system repair any type of troubleshooting you can think of I did. So after doing more research I came across a forum answer that said to disassemble the laptop take out the ac adapter and take out the battery for 1 minute thenhold the power button for 20 seconds and then plug in the ac adapter and press the power button. So I did this and when I put it back together it wouldn't work. Also 3 strips came out so I think that could be part of the problem as well. Can somebody please help me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
you gotta make sure those ribbon cables are in their slots all the way., tbh you might have just ESD bombed your laptop though...
这个答案有帮助吗?
得分 0
2条评论:
What do you by ESD bombed and I think you're right about the ribbons but I don't know where to attach one of the skinny ribbons
完成的
Electro Static Discharge, It's most likely the ribben not being plugged in. Watch a tear down or follow a guide here on IFixIT. It will have the port that the ribben goes into and tell you how to put it safely in.
完成的
添加一条评论
最有帮助的答案
Had the same issue - the laptop wouldn’t turn on after disassembly/reassembly. Unplugging main and CMOS batteries (to clear BIOS settings) kicked the laptop out of limbo.
这个答案有帮助吗?
得分 1
添加一条评论
Push the ON/OFF button for 5 sec..
N then push Task Mgr shortcut..
If successful, reboot the PC.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melyrah Glinsey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 4,717
