跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
My dad's S5 screen displays only a white noise.
Since today my dad's Galaxy S5 started to display only a white noise like seen here.
I tried everything from pressing on different parts of the back, draining it's battery and reinserting it several times, but nothing worked and I can't even go into recovery mode because I can't see anything but the noise.. My dad thinks it's a virus but I have installed an antivirus on his phone and I doubt it could've caught a virus.
Please help me, the last thing we want to do is buy a new phone, but the s5 doesn't even have a scratch and it would've been a bummer to throw it away or pay the price of a second hand one just to repair it, thank you very much in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This sounds more like hardware than software.
You will need to open it and check and clean all LCD screen connectors in the motherboard and screen.
Advisedly to try as well with another LCD screen to discard any damage in current one.
In any case open it and inspect with a magnifier.
Good luck and good repair.
JM - Montreal, QC
这个答案有帮助吗?
得分 1
添加一条评论
Just for any one finding this post.. In the cases I have experienced this is a hardware fault.. I've had it a few times with Galaxy S5's and replacing the LCD has fixed the problem every time..
这个答案有帮助吗?
得分 0
2条评论:
Correction to above post, I'm currently scratching my head over a phone that had the problem and I fitted a new LCD, problem solved.. two weeks later, same issue.. I'm currently downloading new firmware, which is a shot in the dark.. then maybe look at the board.. maybe slap it with a wet sardine.. :(
完成的
I currently have the same problem can't even recovery boot anymore, just white screen. Tried a new LCD same results.
完成的
添加一条评论
添加你的答案
mihailapatrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 1,412
