跳转到主内容
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
28 个问题 查看全部
My driver's side windows buttons quit working
I've changed my speakers and the radio recently and right after i put everything back together the windows buttons quit workig but the door locks works fine only on the driver's side non of the windows worked but on the other doors the buttons worked fine for a while then all the window buttons on all the doors quit working!! But the door lock still work fine! I checked all the fuses and the connections everything looks fine! please help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It might not be the button, it could be that the actual window motors quit working . You may have to check that.
这个答案有帮助吗?
得分 0
1条评论:
The window motor works fine beside it doesnt wvwn get power when i tested the wires
完成的
添加一条评论
It was just a blown fuse but it was a toyota fuse thats why i couldnt see it.
这个答案有帮助吗?
得分 0
1条评论:
Where did you find the blown fuse?
完成的
添加一条评论
添加你的答案
ameedjaara 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 461
