跳转到主内容
宏碁在1997年购买了德州仪器的移动PC部门,从此进入了笔记本电脑的世界。
acer laptop won't connect to wi-fi
i don't know why my acer laptop wireless is not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
i think update the wireless driver and reset the settings of wireless
这个答案有帮助吗?
得分 4
2条评论:
thanks worked for me
完成的
How to update if Wi-Fi not connecting,neither Bluetooth tathering,usb tathering.showing IP address failure.
完成的
添加一条评论
check your device manager.
make sure the device is connected.
try updating the drivers.
这个答案有帮助吗?
得分 1
添加一条评论
i had the same issue i tried everything like reset or update the driver and many more than but nothing just seems to be working with issue . i thought it was the windows and reset the whole computer back to the new settings but still got no success and still having the same issue . now i think i should throw this computer i have no idea what should i do
这个答案有帮助吗?
得分 1
5条评论:
Hi, What is the model number of your laptop? What OS is installed? Has the WiFi ever worked in your laptop? Have you checked in BIOS to see if there is a WLAN enable/disable option?
完成的
i have the same question too . please help
完成的
Hi @ecclescolin,
Provide the answers to my comment above and we'll go from there.
完成的
OS is windows 10 and i am not sure about computer model
完成的
Hi @roberthickman,
On Acer laptops and PCs the model number is written above the serial number on a white label on the the bottom of the laptop or case. if there is none there it is also located in the BIOS area. Press F2 when you first start your laptop/PC to enter BIOS.
完成的
添加一条评论
hi
1-maybe there is problem in WiFi card
2-maybe WiFi driver
3- maybe it isn’t turn on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Turner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,245
