跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
Limited mic vol & no charge/communication
I dropped my 8gig phone (while in a case)no cracks or screen damage, but my mic is low volume, and the connector will not sync w/computer/itunes, and USB charging does not work. When plugged into a firewire charger, it seems to recognize that it is not an approved charger, but the chage icon does not change to charge either. could this be the display assy or the comm board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
Is this a 3G or 2G iPhone? If it is a 3G, you may be able to fix it by simply replacing the dock connector assembly. It's a pretty easy repair, though I don't think iFixit has any guides available- but the teardown should provide a pretty good guide to follow.
这个答案有帮助吗?
得分 1
1条评论:
Not that this is relevant to the question, but we do have the guides.
完成的
添加一条评论
Unfortunately, it is a 2G phone (1st Generation). Could anything have just come loose? I have the unit disassembled at the moment, but have not taken the dock assembly area out of the case. I did find that the connector/cable going to the logic board was not straight, and I straightened it. but it did not seem to make a difference. Any ideas? Thanks
这个答案有帮助吗?
得分 0
添加一条评论
volume limit
这个答案有帮助吗?
得分 0
添加一条评论
The first thing, that appears to me is this black locking bar for dock assembly's ribbon cable on the down side of the motherboard. Maybe you should disconnect and then again connect this ribbon cable to the logic board if you haven't done this already (maybe that's what you meant by straightening it).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hartisja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,060
