Black Screen/External Monitor ONLY ON SAFE MODE
Hello,
Couple of nights ago I close the lid of my macbook and the next day I woke up to a permanent black screen.
I tried Resetting the PRAM, SMC...
I connected an external monitor and nothing happened, until booted in safe mode.
I managed to retrieve my info and boot into recovery (via external monitor) to format and re-install OSX.
Did a clean install and it still wont boot. Tried Safe mode and it worked (external monitor)
So i need your help to understand if it could be repairable or i have an expensive bookend.
Thanks !
4条评论
i have the same problem, did you manage to fix it?
由 susan 完成的
I am with the same problem. I've successfully boot the machine with external monitor in safe and recovery modes.
But the laptop screen is always with black, I only can change de luminosity on it.
Please share if you manage to solve the issue. Thanks ;)
由 mjmabreu 完成的
Hi I also have that, did you work out any solution?
由 filipwiniewicz 完成的
Did anyone got the answer? I have the same issue.
由 netoezequiel 完成的
