跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
632 个问题 查看全部
Fan turns on and off three times, then unresponsive. Advice?
Hello,
I've been refurbishing an Xbox One that was original smashed when I got it. After I got all the parts to repair it, I partially reassembled it to test it. I would go to plug it in, and a few seconds after plug in power, the fan would spin for a few seconds, than turn off. It repeats the process three times, at the same time the power supply goes from orange to white, in the same sequence. The Power button does not light up during this, although you can hear the "start up" sound effect when you press it while the power supply is white.
Here is what was replaced:
- Heatsink and Fan (thermal paste replaced with Arctic Alumina, Fan is a third party replacement.)
- The Full interior and exterior casing for the Xbox.
- Wifi Board
- RF Module Board
- Speaker for button feedback sound
- (The Wifi Antenna will also be replaced when I receive it. There is currently none attached.)
Here is what I've tried so far:
- Different Power Supply (Same result as before)
- Checked Hard Drive for Failures (I was able to navigate the hard drive on my Macbook Pro, so I don't think thats the issue.)
- Attempted hard reset by power button, but it doesn't seem to work.
- Startup from Controller plugged in. (no result)
Any other ideas I can try? This is a 500GB Original Xbox One Model - if I recall correctly, the 1540. (One of the earlier ones) Any advice would be appreciated. I've been testing this with everything installed in the metal casing, with and without the wifi board, with the bottom portion of the outer casing attached.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
This is often times caused by a faulty Southbridge but there are a lot of other things it could be. Usually replacing that chip will fix it but no guarantees.
Sorry I don't have better news for you.
这个答案有帮助吗?
得分 2
评论:
Thanks for the info! Is there anything else I should look at before going after the Southbridge?
完成的
Any burned components or anything that looks like it might be bad or broken on the motherboard.
完成的
Or try to reflow it using the Xbox 360 RROD heat gun fix.
完成的
Turns out the motherboard was more damaged than I original thought - it got cracked from the original damage to it, making it unusable.
完成的
添加一条评论
添加你的答案
Ben Eccles 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 7
总计 471
