跳转到主内容
showing error 15, 156 ,0.
while scanning it show this kind of error like, your usb is not properly attached or scanner is not working, and also shows eroor code: 15,156,0.
My printer is in warrenty period but i dont know how to use this warrenty, where to go and call.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you have a Mac this is what I did and it worked for me.
1 - Place image in scanner.
2 - Turn it on.
3 - Go to System Preferences
4 - Click on Printers and Scanners
5 - Click on the Scan button at the top center of the box
6 - Click on the open Scanner button. A grey Scanner box will appear.
7 - Push start on your Scanner and scanning will commence. I hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
If your USB is properly connected and still you have error because of drivers. Yes, because of old version of drivers. Just uninstall the old one and replace them wit new drivers which you should install from official Canon printer website. After installing drivers, run your scanner if still the error occurs then checkCanon Pixma Mg2570 Manual for other troubleshooting ideas.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maushamrajartist001 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 31
总计 4,058
