跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch wont work after dropped in watter
hello everybody! i have iphone 6.. before 3-4 days it dropped in water (the top of the iphone ) i put it oute quickly i make it dry and after one day iphone open .. but touch wont work.. also i see down on screen some grids you can see the photo i send u
now.. i already order new screen i will change it tomorrow cause i m still on holidays.. but i want ask.. the problem is with lcd & digitizer or its on board? maybe have some water hidden and i must clean better? or if i change the screen it will work fine? thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
thanks for your reply.. i will replace it tomorrow then i already buy one high quality lcd & digitizer A+++ i hope it will be good quality .. i will post the resaults ! thanks again
完成的
添加一条评论
2个答案
已选择的解决方案
Use this teardown to start your water damage repair.
Then use the Water Damage Guide for how to clean up the phone. Be very careful. The guide really is important because you don't want further corrosion in your phone.
Once everything is taken care of, you will definitely need to replace your screen. Follow this guide for the screen replacement, then another for the home button, and lastly, one for your front camera assembly. The home button, camera, and LCD shield will need to be transferred since they do not come with the new screen. Definitely be careful with the home button as you will lose touch ID if you ever have to replace it.
iPhone 6 LCD and Digitizer图片
产品
$69.99
iPhone 6图片
指南
iPhone 6拆解
难度:
中等
iPhone 6 屏幕图片
指南
更换iPhone 6屏幕
难度:
中等
20 minutes - 1 hour
iPhone 6 前置摄像头和感应电线图片
指南
iPhone 6 前置摄像头和感应电线替换
难度:
中等
30 minutes - 1 hour
iPhone 6 Home 键图片
指南
iPhone 6 Home 键更换
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 2
5条评论:
thanks for your informaton! i will follow all guides
完成的
Good luck and keep us posted!
完成的
i follow the steps and i replace the screen .. iPhone open normal but touch still wont work. Maybe have damage on board? should i send it to someone who know fix boards?
完成的
Do you have a grey bar on the top of the screen?
完成的
after i change screen i dont have bar only the touch dont work
完成的
添加一条评论
Your screen has water damage and needs to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
emted16 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 127
