跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
phone doesn't boot up
phone doesn't reboot. i turn it on and it just keep restarting with the unlock logo and samsung logo. what happend was i was on the call and phone suddenly shut off and went blank. i tried to turn it on and now its does the same thing as i have explained above.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi
Try putting phone in download mode and see if it stays on:
To put in download mode press the power+home+volume down button together, then it will show the download mode and press the volume up button to enter download mode.
Leave it on that mode for a little bit and see if it turns off. if it does then the problem is the motherboard and should be covered under the manufacture warranty. You can contact samsung or your provider for that.
If it does not turn off then put your phone in recovery mode and reset the phone and wipe cache. to put in recovery
Turn off your Samsung Note 5.
Press Power , Home and Volume Up buttons together and hold them.
Once you see the Android System Recovery screen, release the buttons.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ajmal78 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 140
