Replace optical drive AND retain original motherboard (from optical)?
I've recently acquired a free Xbox 360 S from a yard sale, yay! Powers on and everything just fine.
However, apparently the previous owner had a baby, and the baby knocked it off the shelf while the DVD drive was open. As a result, this thing's missing the DVD tray!
I think the previous owner managed to completely (and cleanly) remove the DVD tray without any left over mechanical stuff hanging out. He also never opened the Xbox, so that's maybe a plus. However, I think if I were just to order a DVD tray alone online, I would still be missing out on the mechanical bits that push and pull the tray.
I was thinking that maybe I should replace the whole optical drive. I do know that the optical drive is "married" to the mainboard, but I do intend to resell this Xbox and keep it legitimate for play on Xbox Live and read discs.
I was thinking: can I just order an identical model optical drive, and is it possible to swap out the motherboards inside the optical drives so I'm still using the original board? Or are there some complications involving parts soldered into the mechanical stuff? Has something like this been done before?
Update (08/4/2016)
Just an update to all the readers of the thread: I'm currently waiting for a special metal spudger to come in the mail so I can properly open the Xbox 360 S without breaking it, and then a replacement optical drive once I get the model number.
I'm sure the Xbox 360 S was subject to several internal hardware revisions while it was still being actively sold, so I currently have no other option than to be patient.
I appreciate all the input below. I'll update once I get the replacement drive and let you all know if it works or not.
Update (08/11/2016)
Another update! I know I'm slow, but I suppose this all might help someone in a similar situation.
I've managed to get my spudger in the mail and got the Xbox all opened up. Turns out it uses a Philips/Lite-On DG-16D4S optical drive. I've partially disassembled the drive and found the motherboard. It seems to be the only board, so I figure that's where the optical drive's "identity" is stored.
Looks like a soldering iron is needed for this task, as there are some wire leads between the board and motor. Figures.
I'll report back once I get the replacement drive in the mail!
Update (09/08/2016)
Hi! Whoever happens upon this thread. I'm a terrible updater, but my parts have finally arrived and I've performed the motherboard swap between the original drive and the replacement drive.
It works! Problem solved. I can now properly play games and connect to Xbox Live like normal.
1条评论
Thanks for following the updates through, it's made my mind up about a similar fix I'm considering
由 Rob Stringer 完成的
