跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1623 个问题 查看全部
Display rear aluminum separation
The rear aluminum panel on my display is separating what kind of glue is better to re-attach
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Is it separating in the lower lefthand corner?
完成的
at hinge from end to end just lifted
完成的
添加一条评论
1个答案
已选择的解决方案
What I'm trying to determine is if it is just the adhesive or if the inside frame has broken. When they break it usually is on the left hand side about an inch up from the bottom. Yours may have broken which allows the display to flee and pulls the glass loose on the bottom. This may also just be a case of adhesive failure that can be fixed with a heat gun and some pressure. If you can post a couple of pictures if might help to determine the cause. Has the screen ever been replaced?
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
marcheroux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 169
