iMac 是 Apple 的一体机台式电脑产品线。
6564 个问题 查看全部
How do I install drivers for the webcam, speakers and mic?
I reformatted my mac and I'm using windows xp. I did not use the bootcamp so basically its a plain windows computer. i don't have the mac os installed anymore. So my problem now is how do I find the drivers for my other hardware..
thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
All those drivers are built into boot camp. If you wanted a PC why didn't you just get one. They're a lot cheaper.
这个答案有帮助吗?
按维修分数 3
评论:
sorry, forgot to tell you the story behind it. videocard broken and would not run my mac os. used windows xp and disabled the video card just to be able to use it. just trying to look for drivers if any for the hardware if there is. thanks.
There are usually work arounds and you did well. Now think about this work around: Hook up to an external monitor, install the Mac OS and bootcamp. Then install the windows. Set the startup to the Windows with the disabled video. That way it will boot to the windows and still have all the drivers. What do you think?
thanks mayer! got it. looks like a great and simple solution. will try it out. thanks...
You'r welcome. I'm pretty fair at screwy ideas. Apple's old slogan was "Think Different" ;-)
显示更多的2条评论
添加一条评论
添加你的答案
arnie 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 525
