跳转到主内容
加入维修社区 - 创建账户
Dell Latitude E6410 是 Dell 发布的一款 14 英寸笔记本电脑。
Blinking cap locks and won't boot
So being the dummy I am, I spilled some juice onto my laptop. It went though the keyboard and on to the area where my ram is( I know this because there was something sticky in just that part). the power light comes on and so does the fan so I know it's not a power thing. The middle caps lock flashes while the numb and scroll stay solid. I tried replacing the ram but that did nothing. There was also a few times where the dell logo popped up and loaded but then these crazy colored lines appeard on the screen and that was it. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Maybe this could be for help. http://www.laptop-junction.com/toast/con...
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
The colored line is a bad connection between mainboard to screen ( broken or ripped cable, dirt, ...)
Or a failing GPU.
in case of juice spill , you need to clean the main board immediately with isopropyl alcohol. is it long ago the spill?
try to clean it anyway... but do it propperly , use enough of isopropyl ( you can buy this at a drugstore...)
clean every connection.
This is a good time to clean the fan en colling pads as well. check transistors an capicitators for leak also check the chips on the mainboard. clean the ram would help but i think it will be to late , try with other ram after cleaning.
Most of the time the keyboard is dead to.. replace this as well.
Kind regards,
kevin
这个答案有帮助吗?
得分 0
2条评论:
Do you mean clean the motherboard? This all happened last night.
完成的
indeed i mean to open the laptop and clean the components at the motherboard.
if you spill some liquid it will go to the motherboard...
完成的
添加一条评论
添加你的答案
Tariq G 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 9,529
