跳转到主内容
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
How do I turn safe mode off?
Safe mode came on and now I have no volume and I can't power down my tablet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I don't have this problem it just says safe mode in the corner
完成的
添加一条评论
3个答案
The last I heard you put a pin in where earphone goes and hold it
这个答案有帮助吗?
得分 0
添加一条评论
This is the second time I had the problem all right it's very simple turn off your tablet then take something sharp like an earphone or something sharp the end where it would go in in the little hole at the top where you would put the earphone what you do is you put it in you leave it there on the counter 20 pick it up push it back in at the counter 20 as you're turning it turning it on it should be fine
这个答案有帮助吗?
得分 0
添加一条评论
Beside headphone plug and n there is a reset hole u put a pin in and hold down for a few seconds. This should correct the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jamooe48 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 888
