跳转到主内容
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
112 个问题 查看全部
rear brake drums will not come off
how do you get rear drums off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Mike,
Most brake drums will have an adjustment wheel inside the drum, accessible from a slot behind the wheel. You must let the brake shoes in for the drum to loosen. After you do that, it should pull right off.
Reference this prior question for a guide and general diagram on how it works.
Let us know,
Frank
这个答案有帮助吗?
得分 5
3条评论:
Frank, you and your expertise have been missed around here ;-)
完成的
Thanks Mayer. I have been a busy man in this last year, which is a good thing.
完成的
I was just looking at that old question. Two of the links are dead. So here is a link to an exploded view. It will be the brake adjuster screw that needs to be loosened.
http://www.78ta.com/resto/explodrbrakes....
完成的
添加一条评论
If they are not totally froze up...adjust the brakes DOWN (or in) so they are not so tight. TAP all around the drum, (not hard) with something hard, large screwdriver handle, wood, something to help loosen the built up dust. They should come off if they are not totally "welded" together. Good luck
这个答案有帮助吗?
得分 2
1条评论:
If they are totally welded how can you get them to release?
完成的
添加一条评论
Make sure your e-brake is not on. That will tighten the grip the shoes have on the drum and make it next to impossible to remove. Assuming that wasn't the problem...
A lot of brake drums have threaded holes on the face near the lugs. These holes are there to put in jacking screws for drum removal. Find one or two screws that fit the threaded holes and use them to push the drum off.
If there's no such holes, well, get a deadblow hammer and start banging. Penetrating oil from your local auto parts store will also help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mike fairbanks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 24,594
