跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
78 个问题 查看全部
Where do you fix or buy power mac G4 power supplies
how or where do you fix or buy power mac G4 power supplies, Samsung LQ3352ABPoWB, apple pin 614-0224
Update (08/12/2016)
Sorry for the delay, just had world wind of unexpected etc..
Here is the pictures of the psu now finally removed from G4 MDD
add'l zoomed in pictures
do I need to remove fans so I can
lift up housing to get other view?
----- went ahead and unscrewed fans to get other views
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
12条评论
Which machine does this go in? I may have it. There is a new one here: http://www.ebay.com/itm/New-In-Box-Apple...
I think this is a part for an MDD not the machine posted.
完成的
@itspos what have you checked, what machine does it belong to, what are your abilities?
完成的
This is for a powerMac G4, it shut off completely - no power. 1st: I replaced internal battery- nothing. Next,I tried resetting the PMU/cuda switch - nothing. 3rd tried removing battery and resetting PMU/cuda switch + power button, waiting then re-inserting 1/2 aa battery - nothing.
完成的
I have added hard drives and ram to computer but haven't gone much further than those ... but willing. Spent all morning trying to read about how to ground myself before attempting to remove power supply. Still reading
完成的
PowerMac G4 model M8570
完成的
显示更多的7条评论
添加一条评论
4个答案
最有帮助的答案
@itspos check the fuse. Most common failure on these PSU's are
-mains cap shorted
-bridge rectifier shorted
-power MOSFETs shorted
So you do want to take it apart and post some high res images with your question. For that, use this guide
这个答案有帮助吗?
得分 3
16条评论:
okay I will take it apart and post pictures ... I'm game for learning anything I can to fix this "puppy" ...
完成的
Here's how to remove it: Power Mac G4 MDD Power Supply Replacement
UPDATE 7/26/16
Looks like it is Apple part # 661-2816
This one: http://www.powerbookmedic.com/Power-Mac-...
完成的
Not sure if you had a chance to look at pictures of psu opened up.
sorry for delay, just unexpect family stuff ... any insight would be helpful.
Thanks!
完成的
@itspos no problem. Had some family crisis myself. Bad week for that. Anyhow is there any chance you can repost the images after you blow the dustt off the PSU and have the images in a larger format? Hard to see with these old eyes:-)
完成的
I can re-shoot after dusting, but not sure how to make cel photos any bigger at this time. I will shoot in sections as large as I can. It will take a few days.
If computer was working I could enlarge them.
完成的
显示更多的11条评论
添加一条评论
https://www.ebay.com/itm/REPAIR-SERVICE-...
这个答案有帮助吗?
得分 0
添加一条评论
With these older machines its usually best to source another machine for dirt cheap and swap parts between them. Otherwise eBay might have the poeer supply you are looking for.
这个答案有帮助吗?
得分 0
添加一条评论
These PPC G4 PSUs are so old now that even if you did find one on Ebay chances are it will be on its last legs anyway.
So a guide to refurbish a PSU would be awesome as so many g4s could be revived as the PSU is the most common fault.
I have 2 x 933 Quicksilvers that I use for a Pro Tools TDM rig but both have PSU issues now and G4 QS 344w PSUs are as rare as hens teeth.
Even if the guide was split into sections ie part one : replacing mains fuse
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Earth Bound Traveler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 25
总计 940
