跳转到主内容
康柏电脑 所制造的上网本的修理和支持指南。
18 个问题 查看全部
My computer Loss the power after 2 min when charger is pluggged
Computer is working fine when it is in on battery, but when I connect my charger my laptop is loss power(off directly) after 2 to 5 minutes.
Already i check my adapter it is OK, with other adapter same problem occur.
Also i check my power supply of my house no problem was there, It is happen in other home also.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
probably you will have a bad connection in the laptop. Try to replace the DC jack. or try with an other..
If you know enough about electronics, you can try to measure out the PCB connecting your dc tot the main board. I had a same issue to an older model of acer. it was a bad connection in the PCB.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anup Pasari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 65
