跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Any possibility of soldering in a new higher capacity flash drive?
I assume this would require some advanced soldering, but would be possible to replace the SSD with a larger capacity SSD if one was willing to radically violate the warranty and solder one onto the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thanks for all the feedback. Seems like a low-probability proposition right now, and even if there is a replacement option (I'm looking for 1TB) then it still might be a high-risk job. Sigh...
完成的
Sorry, nothing at that high a density available on the market quite yet.
Here's the largest flash just intro'ed just a few months ago: Samsung Mass Producing Industry’s First 512-Gigabyte NVMe SSD in a Single BGA. Two of these would get you 1 TB. I'm sure Apple will offer this size in the fall line up (both Mac's & iPhone's).
Again, you'll want to swap out the logic board here when Apple offers a replacement bd.
完成的
添加一条评论
4个答案
已选择的解决方案
Not a chance in !&&*. Take a look: Retina MacBook 2016 Teardown
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
Sadly no, the density (chips on both sides and very close to one another) on the logic board makes it impossible to desolder these chips without damaging things. It would be cheaper and easier to just swap out the logic board (if you have the 256 GB model).
You also won't be able to find anything larger than 512 GB presently that fits the chips location; Orange block Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash shown 128 or 256 GB one on each side for a total of 256 or 512 GB.
In the next year or two you'll likely see larger density chips but again its just easier to swap out the logic board.
这个答案有帮助吗?
得分 6
1条评论:
It's not a problem density wise, phone repair technicians do this all the time. The flash memory solder pads are large enough.
The problem is that the chips are on both sides so reheating the board at least 4 times (2 times remove the chips and 2 times to solder the new ones, if you aren't quick enough) will very likely to ruin it.
Also, since they are bare flash memory chips, not complete SSD units, you will likely need to do some low-level programming for the system to recognize the new chips.
完成的
添加一条评论
If it is just soldering, it can be done. However the flash memory chips are not like standalone SSD modules, since these chips are designed to be completely embedded to this board, there may be special low-level programming to be done with the new chips.
So I say this is unlikely to be viable.
这个答案有帮助吗?
得分 3
添加一条评论
It might work, but you might have some problems. I've never tried that before with any sort of flash storage, but your welcome to.
这个答案有帮助吗?
得分 0
10条评论:
you have got to be kidding.
完成的
If you do it correctly, it MIGHT work.
完成的
What are going to put in it, where are even going to get it. This is no hack job.
完成的
I said that I've never tried that before, but I can't think of a reason why it wouldn't work if you do it correctly.
完成的
What about from digikey?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Russ McBride 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 4,319
