跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Display works, touchscreen doesn't.
Okay, so I'll start from the beginning. Just got my iPhone a month ago, had a life proof case. I went into a pool with it (stupid me) it got wet. It worked for around 2 days after and then my touchscreen stopped working. I did a restore and it started working again but failed a couple minutes later. The only thing that gets me confused is how the display is perfectly fine yet my touchscreen doesn't work, I feel as though there is a way to fix it but I haven't found anything on the web about it. All buttons work, fingerprint works but can't use it without the passcode. I've tried checking and cleaning the connectors of the display but no luck. Any tips? do I really have to buy another display even though mines working perfectly fine except for the digitizer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Just saw a video after some reasearch about a guy cleaning the connectors with a tooth brush and ipa, going to try it will post results.
完成的
no luck, display still works, touchscreen nope
完成的
添加一条评论
1个答案
已选择的解决方案
My recommendation is to get a professional to perform a water treatment on it asap, as the mother board probably got wet, also the digitiser connection (on the Screen side) can get damaged by water getting in the earpiece speaker hole so a new screen may be needed. I would still recommend getting a water treatment done.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
roswell saldivar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 151
