跳转到主内容
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78 个问题 查看全部
'07'Corolla LE Spontaneous or constant horn
My 2007 Coroll LE horn often honks when the steering wheel is turned. Sometimes the horn honks when car is parked with engine off. Removed fuse as temp control option. Dealer wants $130/hr just to diagnose problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i guess it only can be a damaged Cable, like it has a crack in it and the cracked part connects to some Metal Part on the car and so a short circuit happens. So at first you should have a look at the Cables going to the Horn, and on the Connectors. (Sorry for the Bad English)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lewis Fairchild 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 122
