跳转到主内容
The Lenovo Yoga 2 13" can convert from laptop to tablet, tent, or stand mode with hinges on the side. It was released in January 2014.
38 个问题 查看全部
Why did Windows 10 crash my laptop?
I upgraded to Windows 10 a few weeks ago and my machine gradually took longer and longer to boot up each morning until it stopped working. I took it to Office Depot to get fixed and they couldn't help me. Now it is constantly on the main screen saying auto repairs for days. Any ideas on how I can get my PC back to Normal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Aimee,
Please check out some methods that may work to your problem.
Method 1: Disconnect all the external devices (except mouse and Keyboard ) and then check if the Black screen disappears.
Method 2: Enable the on board graphics device/Intergrated peripherial device from BIOS(Basic Input Output Device) and check.
Warning: Be careful when changing BIOS settings. The BIOS interface is designed for advanced users, and it's possible to change a setting that could prevent your computer from starting correctly. Updating BIOS should only be done if necessary (to solve a compatibility problem, for example). It can be a complicated process, and if an error occurs, your computer could be rendered inoperable. Be sure to follow the manufacturer's instructions exactly.
If none of these methods works, please read the article and see if there’s any solution.
In case of future problem to your Windows, I suggest you to do a system backup with ShadowMaker or the built-in backup utilities in Windows.
Hope this information is helpful. Thank you!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aimee Britt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 261
